piperd
Jun 16, 2018Aspirant
Orbi speed
Have Orbi and 2 satellites hooked up. Wanting to set up video doorbell and exterior cameras, but getting a lot of lag due to slow internet speeds (down 6.24, up 0.62.) the units are connected to 2.4GH...
piperd
RBR50 plus 2 AC2000 satellites.
FW 2.1.4.16
Not sure what am “paying for” - looking into. Runs through ATT arris nvg599. Testing thru phone.
Will try your suggestions. Thx
FW 2.1.4.16
Jun 16, 2018Guru - Experienced User
Check to see if your modem has a built in router as well.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
