RayFinkel
Jul 28, 2023Aspirant
Orbi Speedtest reports 900mbps, but PS4 connection via LAN is poor
Okay, so I use Optimum as my ISP, and I pay for 1 GB internet. I have a Netgear Nighthawk CM1200 as my modem, and Orbi as my mesh network (RBR50 as my router, and 2 satellites). I work and game from ...
CrimpOn
Jul 28, 2023Guru - Experienced User
Can you try different Ethernet cables between PS4 and Router?
Also, look closely at the actual Ethernet jacks on the PS4 and Router. Do all 8 tiny gold wires inside the jack look correct?
Is there any other 'wired' device that can be connected? (laptop? desktop?)
- RayFinkelAug 01, 2023Aspirant
Thank you for your reply! It is a good cable (new) Cat6 with gold tip. Same results when I use the Cat5 I have laying around đ
Do you know of any issues specifically between Orbi and PS4? I am really at a loss...
