RayFinkel
Jul 28, 2023Aspirant
Orbi Speedtest reports 900mbps, but PS4 connection via LAN is poor
Okay, so I use Optimum as my ISP, and I pay for 1 GB internet. I have a Netgear Nighthawk CM1200 as my modem, and Orbi as my mesh network (RBR50 as my router, and 2 satellites). I work and game from ...
CrimpOn
Jul 28, 2023Guru - Experienced User
Can you try different Ethernet cables between PS4 and Router?
Also, look closely at the actual Ethernet jacks on the PS4 and Router. Do all 8 tiny gold wires inside the jack look correct?
Is there any other 'wired' device that can be connected? (laptop? desktop?)
RayFinkel
Aug 01, 2023Aspirant
Thank you for your reply! It is a good cable (new) Cat6 with gold tip. Same results when I use the Cat5 I have laying around đ
Do you know of any issues specifically between Orbi and PS4? I am really at a loss...
