ThePablo
Dec 09, 2017Aspirant
Orbi speedtests showing higher than other apps
So I’ve been noticing as of late that when running the included Speedtest within the Orbi app I consistently get 114mb, but am running the app by Ookla and get 8-10mb. Why such the difference? Aren’t they both testing the same thing, or is the Orbi one not checking actual internet. Confused. Thanks for any help.
Not sure why the built-in test shows a higher number but I do know that using the built-in Speedtest has caused problems with Orbi for some folks. Several threads recommend NOT using the built-in Speedtest due to WiFi anomolies showing up after running that test. I'm still running firmware 2.0.74 and NEVER do a Speedtest from Orbi's built-in. I would not trust the built-in numbers. Cannot say if latest firmware solved this issue.
- tucsonticoVirtuoso
- ThePabloAspirant
Thanks for the tips and suggestions of not running in-app. I confirmed I am using 2.0.74, so I just rebooted my network and will continue to keep an eye on the connection. I will validate, and possibly restart my cable router as well.
If you connect directly to your modem (no router) what download speed do you get?
