Mikener
Jun 27, 2020Aspirant
Orbi SSDI Reuse and Virus protection questions from a Newbie to networking
SSID QUESTIONS: I had always thought when I upgraded from one router to the other that I couldn’t or shouldn’t reuse SSDI name and password that I used on my existing router. I am upgrading from a l...
- Jun 27, 2020
FURRYe38 wrote:Not sure where you heard that but you can always re-use and retain SSID names and PWs if you like, thought it's recommended to change the PW to keep some hackers out. I've been using the same SSID name for almost 20 years.
Keeping the same WiFi name (SSID) and password accomplishes two tasks:
- It means the every device that was connected to the old WiFi router should connect automatically to the new WiFi router without having to be reconfigured. Changing the password, renders this impossible. If the password is changed, then every device has to be connected to the new WiFi system individually. This can be an lengthy and tedious process.
- It means that you can "go back." The new WiFi system can be unplugged, the old system reinstalled, and every device will connect automatically.
I highly recommend using the same WiFi name and password every time the WiFi system is replaced.
Jun 27, 2020Guru - Experienced User
You don't have to enable Armor. Just skip it if you don't want to activate it.
There is a Armor forum if you have additional questions:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
Enjoy.
- CrimpOnJun 27, 2020Guru - Experienced User
- MikenerJun 28, 2020Aspirant
Thanks for always being so helpful to me. I plan to install the router in the next few days. I'd like to purchase a surge protector first.
- Am I correct that in some point in the future that if I choose to that I could change the SSDI name?
- Am I correct that the virus checker is installed optionally?
- Do you use the virus checker? It seems like overkill since my devices use virus checkers.
- Does the virus checker impede performance?
- Does the virus checker update itself automatically or is this something that I need to do myself every few days?
Sorry for these additional questions. They just popped into my head and with my family driving me so crazy about the WIFI, I get very nervous about not knowing what I'm doing.
Thanks again.
- CrimpOnJun 28, 2020Guru - Experienced User
Mikener wrote:Thanks for always being so helpful to me. I plan to install the router in the next few days. I'd like to purchase a surge protector first.
Yes. Like all WiFi routers, each Orbi comes from the factory with a default SSID/password already set and printed on the product label. Orbi products are named "ORBI" plus two digits. In order to avoid reconfiguring all of the existing devices, I would change that SSID/password to match the existing one. It can be changed at any time. - Am I correct that the virus checker is installed optionally?
Yes, Bitdefender Armor is an option, but you have to be alert or Armor and Disney Circle will get activated for a "Free Trial" after which Netgear will charge an annual fee. (They want the revenue.) - Do you use the virus checker? It seems like overkill since my devices use virus checkers.
I cannot comment on how well it works because I have never activated either product. Most of the users who post about Armor and Circle on this forum are here because they are trying to solve issues and the solution is often to remove them. - Does the virus checker impede performance?
It clearly uses resources. No one has commented on this being a major issue. - Does the virus checker update itself automatically or is this something that I need to do myself every few days?
Yes. Updates are totally automatic.
Thanks again.
Thank you. And thanks for the link to Armor. I just noticed it.
