jweaver0312
Dec 12, 2017Aspirant
Orbi SSID
Hi. I am considering buying an Orbi. I read one single Wi-Fi name. Could I change that for both bands and have for example Orbi-2.4GHz (for 2.4GHz) and Orbi-5GHz (for 5GHz devices)?
- Dec 13, 2017
Hello jweaver0312
no orbi does not allow you to separate out the the SSIDs. Your devices will connect to the best available connection when on orbi.
DarrenM
DarrenM
Dec 13, 2017Sr. NETGEAR Moderator
Hello jweaver0312
DarrenM
- jweaver0312Dec 13, 2017AspirantOk. Thanks. I was hoping it would and would be nice if it would.
- tagteamDec 13, 2017Virtuoso
jweaver0312 wrote:
.....I was hoping it would and would be nice if it would.
There is, however, a workaround which will separate the two networks (link below), but it is not officially recommended.
https://community.netgear.com/t5/Orbi/How-to-set-a-separate-SSID-for-the-5-GHz-network-on-your-Orbi/m-p/1396594#M14929
