cjuliom
Jun 08, 2017Initiate
Orbi Starter Kit RBR50 (Router Only)
Hi, im looking for a Orbi starter kit (Router only) for my apartmet (1500 sq ft ) built whit briks walls. I have a question about its solo preformance, if it isn`t working whit a satellite it mea...
- Jun 08, 2017
The backhaul radio is available for the backhaul only. If you buy the router alone with no intention of buying a satellite, you would be paying for an expensive 4x4 backhaul radio that would never get used. If a single AP can provide the coverage area you need, you'd be better off with another solution.
st_shaw
Jun 08, 2017Master
- cjuliomJun 08, 2017Initiate
Thaks a lot st_shaw, i will take your advise.
