cjuliom's avatar
cjuliom
Initiate
Jun 08, 2017
Orbi Starter Kit RBR50 (Router Only)
Hi, im looking for a Orbi starter kit (Router only) for my apartmet (1500 sq ft ) built whit briks walls.   I have a question about its solo preformance, if it isn`t working whit a satellite it mea...
  • st_shaw's avatar
    Jun 08, 2017
    The backhaul radio is available for the backhaul only.  If you buy the router alone with no intention of buying a satellite, you would be paying for an expensive 4x4 backhaul radio that would never get used. If a single AP can provide the coverage area you need, you'd be better off with another solution.
