jamckeon88
Sep 09, 2020Aspirant
Orbi: STAY AWAY!!
I got this router with one satellite yesterday. This morning when I go to log into my ATT account to pay my bill... I’m redirected to this ( see attached picture) Come to find out this happens anytim...
- Sep 10, 2020
This is not a Orbi nor a security or hacking malware issue!!!
There a built in router here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
CrimpOn
Sep 09, 2020Guru - Experienced User
- There is no need to download an app to install and use an Orbi. That option is included (a) because everybody else offers it, and (b) customers seem to want it. I always use the web interface to set up WiFi routers, including the Obri.
- During the install, did you activate Bitdefender Armor (in the app, it is called "Security")?
That creates "additional protection", a feature that I declined. - What URLs do you enter to connect to these sites?
If the login page is "http" rather than "https", then yes you are sending account information "in the clear."
jamckeon88
Sep 10, 2020Aspirant
Did you look at the picture I attached? That’s what came up when I went to att.com and any other website that asks for login information.
- jamckeon88Sep 10, 2020AspirantI don’t think http or https would matter, because I’m being redirected to some sketchy website. With my Orbi gone, this no longer happens.
- FURRYe38Sep 10, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop - FURRYe38Sep 10, 2020Guru - Experienced User
So what seeme to resolve this for you?
