jamckeon88
Sep 09, 2020Aspirant
Orbi: STAY AWAY!!
I got this router with one satellite yesterday. This morning when I go to log into my ATT account to pay my bill... I’m redirected to this ( see attached picture) Come to find out this happens anytim...
- Sep 10, 2020
This is not a Orbi nor a security or hacking malware issue!!!
There a built in router here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jamckeon88
Sep 10, 2020Aspirant
Did you look at the picture I attached? That’s what came up when I went to att.com and any other website that asks for login information.
jamckeon88
I don’t think http or https would matter, because I’m being redirected to some sketchy website. With my Orbi gone, this no longer happens.
- FURRYe38Sep 10, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop - FURRYe38Sep 10, 2020Guru - Experienced User
So what seeme to resolve this for you?
