jamckeon88
Sep 09, 2020Aspirant
Orbi: STAY AWAY!!
I got this router with one satellite yesterday. This morning when I go to log into my ATT account to pay my bill... I’m redirected to this ( see attached picture) Come to find out this happens anytim...
- Sep 10, 2020
This is not a Orbi nor a security or hacking malware issue!!!
There a built in router here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Mstrbig
Sep 10, 2020Master
Come to find out this happens anytime I go to a website that asks for login information. My old router does not do this and it doesn’t happen when I use cellular data. WTF is this? Did this thing come infected with malware, pretty much straight out of the box? Was it included in the firmware update? What a joke. I knew I was in trouble when I had to download an app just to use this thing.
Did you purchase the new? If not I suggest factory resetting it before you do anything.
If new, do not setup Armor or Circle, as that may be your issue.
I can vouch that the Orbi line is one of the best available. So your issue is propably related to settings.
