85percent
Nov 05, 2017Follower
Orbi, still disconnecting
I just bought this Orbi system, and I installed the very latest software on both the router and the satellite. Every 45 minutes or so, the satellite turns magenta and I lose internet signal. The sat...
Retired_Member
Nov 05, 2017Move it closer. Yes, 20 feet is close, but it may need to be 15 or 10 or 1 after the 2.0.x release.
- Greyhawk68Nov 25, 2017Star
This should not have to be closer. 20ft? C'mon. I know you are being snarky but this thing should have some range.
And yes, I'm having the same issues, for the last month, and it's been infuriating.
- Retired_MemberNov 26, 2017Seriously not being snarky. I had to move mine from about 40 ft to 15 and 20 for my two sats.
- Greyhawk68Nov 27, 2017Star
Man that seems really bad, the router should give you way more than a 20ft distance. That's kind of the whole point of the housewide mesh system. Ugh. Hopefully it will get resolved.
