nadavN
Jan 26, 2019Aspirant
Orbi stopped working unless i do a factory reset ORBI RBR20
Hi ,
my ORBI mesh network was working great for 5 months ' but during the last month the internet connection stopps working every couple of days and cann't be set right unless performing a factory...
Jan 26, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
Be sure the BeamForming and MIMO are enabled.
nadavN
Jan 28, 2019Aspirant
Hi ,
thanks a lot , i've tried some of it (the Daisy Chain diasbling + the channel set to 11 ) , waiting to see if i have to change more (as i don't understand some of the definitions, i'd rather not change them all ) .
the house in general is 140 m^2 (1 floor) , no neighbors nearby , again , i had no issues for the first 5 months , and nothing changed in the system or usage.
in any case , in the meantime it seems to be working (i didn't reset to factory settings ' just changed the above + restarted) ., i'll wait and see if it holds up .
Thanks!
Nadav
- FURRYe38Jan 28, 2019Guru - Experienced User
Ok Sounds good.
nadavN wrote:
Hi ,
thanks a lot , i've tried some of it (the Daisy Chain diasbling + the channel set to 11 ) , waiting to see if i have to change more (as i don't understand some of the definitions, i'd rather not change them all ) .the house in general is 140 m^2 (1 floor) , no neighbors nearby , again , i had no issues for the first 5 months , and nothing changed in the system or usage.
Thanks!
Nadav
