nadavN
Jan 26, 2019Aspirant
Orbi stopped working unless i do a factory reset ORBI RBR20
Hi ,
my ORBI mesh network was working great for 5 months ' but during the last month the internet connection stopps working every couple of days and cann't be set right unless performing a factory...
nadavN
Jan 28, 2019Aspirant
Hi ,
thanks a lot , i've tried some of it (the Daisy Chain diasbling + the channel set to 11 ) , waiting to see if i have to change more (as i don't understand some of the definitions, i'd rather not change them all ) .
the house in general is 140 m^2 (1 floor) , no neighbors nearby , again , i had no issues for the first 5 months , and nothing changed in the system or usage.
in any case , in the meantime it seems to be working (i didn't reset to factory settings ' just changed the above + restarted) ., i'll wait and see if it holds up .
Thanks!
Nadav
Jan 28, 2019Guru - Experienced User
Ok Sounds good.
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
Is the Orbi system operating in Router or AP mode?
nadavN wrote:
Hi ,
thanks a lot , i've tried some of it (the Daisy Chain diasbling + the channel set to 11 ) , waiting to see if i have to change more (as i don't understand some of the definitions, i'd rather not change them all ) .the house in general is 140 m^2 (1 floor) , no neighbors nearby , again , i had no issues for the first 5 months , and nothing changed in the system or usage.
Thanks!
Nadav
