Zaichik
Sep 06, 2020Aspirant
Orbi stopped working with ethernet switch
Hi, I have an Orbi RBK50 system with 2 satellites. Some devices are connected to the router using ethernet and a Netgear GS308 unmanaged ethernet switch. Until yesterday, everything worked fine....
Mstrbig
Sep 06, 2020Master
My first thought would be the switch. But since you swapped out the switch with a known working switch, I would now check the cable coming from the Orbi to the switch.
- ZaichikSep 07, 2020AspirantThanks. I've tried changing the ethernet cable with a couple of others that I know work elsewhere in the house. Still no dice.
- MstrbigSep 07, 2020Master
Zaichik wrote:
Thanks. I've tried changing the ethernet cable with a couple of others that I know work elsewhere in the house. Still no dice.What happens when you bypass the switch and plug one device's cable directly to the Orbi?
- ZaichikSep 07, 2020AspirantAs noted in my original post, if I connect the devices directly to the Orbi's ethernet ports, they connect fine. Everything points to the switch being the issue so you would think that changing the switch would have fixed things. That's why I'm so baffled.
