Bossie81
Jul 31, 2020Aspirant
Orbi stopped working
Hi, I have an orbi 50 with 2 satilites for 1,5 years. Never had a problem. Installation with the app went smooth back then. but no yesterday orbi lost internet connection all of a sudden. I w...
- Aug 08, 2020
Glad its working. I am curious on what happend to get it working.
I would keep an eye on it. if it fails again or something happens, contact NG support.
I would say mark your thread as solved however not having an idea of what was fixed or how....
Would be good if you could give feedback to some of the questions presented.
Enjoy.
Bossie81 wrote:Thanks, I didn't know what the problem was. But I contacted Netgear Belgium, they said to ship it back to the store for repair. That my orbi still was under warranty.
So after more of a week of not working I prepared a "return for repair" on the Webstore where I bought it.
And just when I wanted to dismantle my orbi I had the urge of just trying to conect to my WiFi for one last time (although I tried it more then 10 times in the previous days...) and all of a sudden I got internet.... I have no idea what went wrong or why it started to work again on its own after a more then a week that it didn't work... but when WiFi was back, the orbi app did show a update status. So I did that update. And since no problems and all works fine again, WiFi signal shows full bars in all my rooms (and 2 bars in the garden)... just as it used to be.... so my happy again :)
Jul 31, 2020Guru - Experienced User
Use a wired PC and web broswer to connect to the RBRs web page at 192.168.1.1 after the reset.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- Bossie81Aug 08, 2020Aspirant
- MstrbigAug 08, 2020Master
Glad to hear you got it working!
- FURRYe38Aug 08, 2020Guru - Experienced User
Enjoy.
