AussieCJ7
Jan 09, 2020Aspirant
Orbi stops fowarding traffic
This thread is out of pure frustration with terrible support from Netgear, and hopefully will allow others considering orbi not to make the same mistake Orbi has a critical software defect that b...
AussieCJ7
I believe there is a number of people seeing this issue based on the number of support community threads that describe symtoms of intermittent lock ups, given the wide range of techincal backgrounds of the user community some of these symptoms have been described more in a more generalist form others have got much closer to the issue but none have been resolved. I have even seen comments of people writing scripts to reboot every evening to try and prevent this issue out of frustation.
As of last night it appears my logs have made to to level 3 so hopefully there is enough in them to get to root cuase in the code. I did finally get a call back howvever very disrepectful 01:35hrs just makes it even worse with a already dis-satisfied customer.
