AussieCJ7
Jan 09, 2020Aspirant
Orbi stops fowarding traffic
This thread is out of pure frustration with terrible support from Netgear, and hopefully will allow others considering orbi not to make the same mistake Orbi has a critical software defect that b...
euidhawiojp12
Jan 17, 2020Aspirant
It's probably every hour to hour and a half that it stops traffic. I've rebooted my fiber gateway, main Orbi and sat Orbi in correct sequence as well. I installed the older firmware which kept for all of 20 minutes before the Orbi automatically upgraded itself back the newest. So annoying.
CrimpOn
Jan 17, 2020Guru - Experienced User
Orbi RBR50 automatically updating stopped once firmware 2.3.0.30 was released early last summer. Which firmware release is this Orbi on now?
This system sounds like an ideal candidate to test my theory about DHCP renewals. Can you set up a capture to USB and let it run through at least two failures, with restart by DHCP Renew rather than reboot?
p.s. How are you doing the DHCP renew? (telnet session command?)
