MilesB
Feb 16, 2017Guide
Orbi stops responding overnight
I've recently got an Orbi and successfully set it up with my broadband connection. It works fine throughout the day, including long periods of inactivity, but I find it stops responding overnight. ...
- Jul 12, 2017
My RBR50 no longer drops! It's been up for almost 48 hours!
Version: V1.12.0.18
Steps: Updated firmware, reset Orbi router to factory, resync'd each satallite. Thanks Netgear Orbi Team!
MilesB
Mar 26, 2017Guide
I updated to the latest firmware and it's had no effect.
I've tracked down something that's triggering it. If I disable (unplug) the satellite, everything remains fine overnight, but of course I don't have a great signal upstairs so the Internet is slow.
I've can't see anything obviously wrong, or if there are many settings to configure a satellite. I tried resetting the backhaul password, but that didn't help.
Any ideas?
- DarrenMMar 29, 2017Sr. NETGEAR Moderator
Hello MilesB
You may want to work with support if you have found the issue is just the sattelite causing the issue.
https://www.netgear.com/support/contact.aspx
DarrenM
