JCRRTX's avatar
JCRRTX
Follower
Jun 20, 2019
Orbi Stops Working Daily
My Orbi RBR20 router stops broadcasting wifi almost everyday.  I have to turn it off and restart the router for it to start working again.  I have updated it with the latest firmwater and it still does this.  Any suggestions on how to fix this would be great.
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
