fcarmonabr
Apr 02, 2018Tutor
Orbi stops working
I have been using my Orbi since April / 2017 without major problems, but tonight the system just stopped to work and the lights turned magenta. Turned on and off and now I can't see my WiFi network an...
Apr 02, 2018Guru - Experienced User
Please try the new Beta FW:
After the installation, factory reset the router and satellite then setup from scratch. Use a ethernet wired PC to do the upgrade.
If this fails to fix this, I presume you'll need to phone connect with NG support and ask about an RMA.
tagteam
Apr 02, 2018Virtuoso
- FURRYe38Apr 02, 2018Guru - Experienced User
AH, type in RBK50 and it's there.
Thanks.
tagteamwrote:It's not beta firmware any longer. :-)
https://www.netgear.com/support/download/
