fcarmonabr
Apr 02, 2018Tutor
Orbi stops working
I have been using my Orbi since April / 2017 without major problems, but tonight the system just stopped to work and the lights turned magenta. Turned on and off and now I can't see my WiFi network an...
Apr 02, 2018Guru - Experienced User
I would contact NG support and ask about an RMA if geek squad can't help you. Something is going on with your router.
fcarmonabr
Apr 02, 2018Tutor
Thanks for your tips, I really appreciate it. I decided to get a new mesh network (EERO PRO) after hearing about all problems and returns of Orbi System. It is sad, because I just lost 370 and I was always a Netgear supporter... I will try to reach them out and see what they can do with this defective unit and if they fix it, I will probably give it to a friend of mine.
- FURRYe38Apr 02, 2018Guru - Experienced User
Hope they can.
Good Luck.
