rce3
Jul 24, 2017Guide
Orbi STP/BPDU errors
Hi - looking for some information about how Orbi uses the STP/BPDU protocols. Can't find any via google, so hoping that someone here knows more. I am using an Orbi RBK50 in AP mode plugged into ...
rce3
Jul 24, 2017Guide
It's the router that's plugged in to the Edgeswitch, though again operating in AP mode. I believe it is the Orbi router that is causing the problem as the error messages stop when I unplug the router and resume immediately when I replug the router.
I've not plugged the satellites in yet, so can''t comment on whether they also generate this error.
I know that the Ubiquiti Unifi switches are slightly different than the Ubiquiti EdgeMax switches, but I'm not familiar with the details. My system is working, in the sense that wireless devices can connect via the Orbi Router and work fine. It's only when I inspect the system logs on the EdgeSwitch that I notice this error. When you say your system has no issues, have you looked at the system log?
Thanks!
-Robert
st_shaw
Jul 25, 2017Master
Thanks for the further detail.
I expect that plugging-in the satellites would cause issues, such as a network loop. That's why I asked.
I looked at the "Events" in the Unifi controller and don't see any errors noted there. I'll need to SSH into the switch to see if there is a log there analagous to the Edgeswitch. There's no GUI on the Unifi switches.
- st_shawJul 25, 2017Master
I logged into the switch via SSH and looked at the log in /var/log/messages.
No spanning tree errors. Plenty of messages about the spanning tree config changing, and a new root being selected, etc. I have a Sonos system, which uses STP, so it just looks like normal STP operations..
- rce3Jul 27, 2017Guide
Interesting.
I do have a Sonos speaker as well as a variety of other wifi devices in the house which could in theory be connecting via the orbi and sending the bad bpdu packet. To be sure, I'll have to wander around the house turning off all wifi items and see if the problem goes away.
I'm also getting some advice from the ubiquiti forum on how to capture those bpdu packets and inspect them for source and problem.
Looks like I have a project for the weekend... I'll report back then.
- st_shawJul 27, 2017Master
I was going to ask if you had Sonos. There have been reports of Sonos causing problems with STP-enabled switches.
I have two sites with Sonos and Ubiquiti switches, with no issues noted.
For both sites I have:
1. Sonos "Boost" setup, not a "Standard" setup (I'm not using WiFi for Sonos).
2. One, and only one, Sonos device wired to the network.
3. The switch closest to the router is set with an RSTP priority of 16384.
4. Switches connected to the first level switch are set to RSTP priority of 32768.
