aellul
Jul 23, 2017Star
ORBI strange issue HELP PLEASE
Hi all, I have a very strange issue with my ORBI and to be honest I have never ever came across this on any router. I have have set up the ORBI router downstairs and the satellite upstairs. ...
Nsiddons
Aug 01, 2017Apprentice
I don’t have a solution but more questions. Have you changed any setting in the 2.4g or 5g or did you leave those settings default? When you turn off the guest network does your dells drop the wifi connection? When you turn off the guest network can your dells see the main wifi still?
aellul
Aug 02, 2017Star
hi,
the only thing i changed was the channel for teh 5Gzh network and set it to 40.
when i switch off the guest network on the orbi the dell is still able to connect to other networks and the dell's wifi does not drop. it is like it becomes invisible when i switch off the guest network.
no, when i switch off the guest network the dell does not see the orbi at all.
thanks
