ChuckieCheese
May 28, 2020Luminary
Orbi suddenly will not receive IP address from Xfinity Internet
I have Xfinity Internet service with Motorola MB7621 modem connected to RBR50. It has been working just fine, but suddenly it stopped working. After spending hours troubleshooting this with Xfini...
- May 29, 2020
Oh yeah, I forgot to mention I did connect the laptop to the modem directly and it's on and off.
Example:
1. Power cycle modem, disconnect Orbi, modem up, connect laptop, got an IP
2. Power cycle modem, disconnect laptop, modem up, connect Orbi, no IP
3. Power cycle modem, disconnect Orbi, modem up, connect laptop, no IP
For each power cycle, I waited 5 minutes.
Jetdrive wrote:
Did you plug your laptop into the modem and check to see if it gets an IP?
Jetdrive
May 29, 2020Luminary
Yes you can restore the saved config. That's the purpose of saving the config so you can restore it without manually having to set up everything again.
ChuckieCheese
Example:
- FURRYe38Jun 01, 2020Guru - Experienced User
A reset of the RBR and power cycle of the modem should bring the system up and running and connected.
Please mark your thread as solved so others will know.
Enjoy.
ChuckieCheese wrote:Oh yeah, I forgot to mention I did connect the laptop to the modem directly and it's on and off.
Example:
