Ragar99
Jan 09, 2019Luminary
Orbi Support for 4K Arlo Ultra seen at CES?
Saw the new 4k Arlo Ultra this week at CES and wondered if this complex issue would prevent the Orbi from being able to support it.
JoeCymru
Jan 10, 2019Virtuoso
Though Arlo was spun off from Netgear, they still own a huge chunk of it. The entire Arlo spin off was a cash raising ploy to move forward with the Arlo brand and new device roll outs. Though operating as separate companies, they are still deeply entwined. Arlo rolling out a product that could not be effectively supported by its first-cousin company is probably not an issue. The issue, in my opinion, would be Arlo - who has a poor record of updates to support the flurry of new products and features in existing basestations and apps - breaking existing Arlo systems.
- michaelkenwardJan 10, 2019Guru - Experienced User
But that will change gradually as Netgear completes the process started by last year's IPO for Arlo.
- Ragar99Jan 10, 2019Luminary
Stock soars? It has lost 2/3 of it's value.
- michaelkenwardJan 11, 2019Guru - Experienced User
It is called the stock exchange.
Ask Apple.
