BeeKayPea
Dec 01, 2016Aspirant
ORBI Support for WPA2 Enterprise?
Does anyone know if the ORBI really supports WPA2 Enterprise? This KB entry says that it is supported: http://kb.netgear.com/app/answers/detail/a_id/31215/~/what-are-the-security-features-on-my-...
- Dec 01, 2016
BeeKayPea wrote:Does anyone know if the ORBI really supports WPA2 Enterprise?
This KB entry says that it is supported: http://kb.netgear.com/app/answers/detail/a_id/31215/~/what-are-the-security-features-on-my-orbi-wifi-system%3F
But I cannot find it in the GUI interface anywhere.
nope only supports
WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES]
prob will be added later
at this point in time
IFlyNavy
Dec 06, 2016Aspirant
Bee
I saw the same thing and was irritated. I have tried to get around it using Mac based authentication from the switch side but I'm seeing issues there with the clients authenticating every second. I'm thinking the Orbis is tweaking the packet somehow.
They really need to add this. It's not difficult and considering thier docs say it has it.....
BeeKayPea
Based on the release notes it does appear that they're adding features regularly so hopefully this is on the road map.
For now its probably sufficient to use a random shared key of very long length.
