ChuckinJapan
Dec 11, 2021Star
Orbi surface cleaning
I have an ORBI RBR50 + Satellite that is about 6 years old (4UX26B5E000C4) and still in excellnt working order. But the surface of both units has become "sticky", so that dust aheres to it and wo...
Dec 11, 2021Guru - Experienced User
I usually just spray a cloth with cleaner and then wipe the orbi. I make sure its not dripping wet, just damp before wiping. I also make sure its powered off.
I have one thats in an area that gets a bit dirtier and thats all I do.
