Elvisj
Jan 17, 2017Star
Orbi switch connection
I have the Orbi router and three satellites. I need to connect three 24 port switch boxes to the network. Must I connect the switches to the router or can I connect a switch to each satellite?.
Elvisj
Jan 17, 2017Star
Thanks, I have a 6,000 sf house and have widely distributed TVs, music, cameras and phones, which is why I spread 3 24 port switches within the house. Not all are full, but I like a port available when needed. I doubt speed is critical so I will test moving the switches to satellites, because running long ethernet wires across the attic from one router is difficult.
st_shaw
Jan 17, 2017Master
That's a large area to cover. It sounds like you already have the three switches installed and wired back to a router. Is that the case?
