Markwilliam
Mar 06, 2018Aspirant
Orbi, synology, media server
With a synology nas running media server connected wired to a dlink dir router my LG TVs could see the synology device over WiFi and play the contents. However with the exact same setup but replaci...
- Mar 07, 2018
Well this is completely the opposite to what I expect and the dir-850L
I got it working. The lg tv sees the nas oddly by turning off upnp on the orbi.
Mar 06, 2018Guru - Experienced User
What is the Mfr and model # of the ISP modem?
Is uPnP enabled on the Orbi router?
What is the Model# of the DIR router?
However with the exact same setup but replacing the dlink with the Orbi I cannot see the synology device in the list of devices when trying to connect from the LG tv.
All other devices can see the nas however they don’t rely on the media server. The media server is using upnp.
The LG tv also says multicast must be supported.
Anyone come across the same issue?
I can put specs and screen shots if required.
Markwilliam
Thanks for replying. I will look up the specs tonight singapore time so maybe a bit of a delay depending where you are. Also I have a wedding, not mine, to attend so there might be a longer delay.
Incidentally this works without the isp modem as it’s all local networking. Local nas with media going to local tv via local router. Which works fine with dlink. Also worked fine when dlink was connected to isp modem.
I will put up all the specs though as it helps.
I will also reset the Orbi as I saw a large number of port forwarding rules related to the IP address of the synology nas which is not in the dlink and maybe as I was trying to resolve another issue concerning seeing the nas on the internet via synology free Dbs service. But the issue was a gateway setting in the nas since dlink ran on 192.168.0.1and Orbi was 192.168.1.1
For testing of tv connectivity both Orbi and dlink are on 192.168.1.1 so consistent there.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
