Markwilliam
Mar 06, 2018Aspirant
Orbi, synology, media server
With a synology nas running media server connected wired to a dlink dir router my LG TVs could see the synology device over WiFi and play the contents. However with the exact same setup but replaci...
- Mar 07, 2018
Well this is completely the opposite to what I expect and the dir-850L
I got it working. The lg tv sees the nas oddly by turning off upnp on the orbi.
Mar 06, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
However with the exact same setup but replacing the dlink with the Orbi I cannot see the synology device in the list of devices when trying to connect from the LG tv.
All other devices can see the nas however they don’t rely on the media server. The media server is using upnp.
The LG tv also says multicast must be supported.
Anyone come across the same issue?
I can put specs and screen shots if required.
- MarkwilliamMar 07, 2018Aspirant
- FURRYe38Mar 07, 2018Guru - Experienced User
Maybe use to the Synology Media server already having uPnP service running?
Glad you figured it out.
Markwilliamwrote:Well this is completely the opposite to what I expect and the dir-850L
- MarkwilliamMar 08, 2018AspirantGood point. I’ll check and report back.
- MarkwilliamMar 08, 2018AspirantI think you are right. It’s nice to tie up loose ends like why works with upnp off on the router. Cheers.
https://www.synology.com/en-global/knowledgebase/DSM/tutorial/Multimedia/How_to_enjoy_multimedia_contents_stored_on_Synology_NAS_with_DLNA_UPnP_compliant_DMAs
