Markwilliam
Mar 06, 2018Aspirant
Orbi, synology, media server
With a synology nas running media server connected wired to a dlink dir router my LG TVs could see the synology device over WiFi and play the contents. However with the exact same setup but replaci...
- Mar 07, 2018
Well this is completely the opposite to what I expect and the dir-850L
I got it working. The lg tv sees the nas oddly by turning off upnp on the orbi.
Markwilliam
Mar 07, 2018Aspirant
Mar 07, 2018Guru - Experienced User
Maybe use to the Synology Media server already having uPnP service running?
Glad you figured it out.
Markwilliamwrote:Well this is completely the opposite to what I expect and the dir-850L
- MarkwilliamMar 08, 2018AspirantGood point. I’ll check and report back.
- MarkwilliamMar 08, 2018AspirantI think you are right. It’s nice to tie up loose ends like why works with upnp off on the router. Cheers.
https://www.synology.com/en-global/knowledgebase/DSM/tutorial/Multimedia/How_to_enjoy_multimedia_contents_stored_on_Synology_NAS_with_DLNA_UPnP_compliant_DMAs- FURRYe38Mar 08, 2018Guru - Experienced User
Glad you got it working.Enjoy. :smileywink:
