superczar
Jun 22, 2020Apprentice
Orbi system - Faulty LAN / switching design - Will NG ever fix it?
Issue - Orbi system with 2 satellites (R1, S1, S2) will randomly drop LAN communication between segments. e.g. devices connected to S1 (both wired/wireless) won't be able to ping devices on S2 (or ...
Jun 23, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
superczar
Jul 27, 2020Apprentice
So another update on this perpetual problem:
What works mostly stable - Leaving all devices on 2.1.4.16 with updates / Internet access blocked at the firewall
It's usually weeks (or a power outage) after which this situation recurs .
At each major firmware iteration, I update to see if it solves the issue but alas, it only makes it worse.
Anyway , After the latest firmware (2.5.1.32 (?) ) , I had to take the RESET route to to do a clean revert to 2.1.4.16
A few days later, I realized the guest network was left on its default off setting so I enabled the guest network and right after, the LAN segment on the RBS50 stopped responding (Internet working as expected on all devices)
So I disabled guest network and the RBS50 devices re-appeared.
I am going to leave the guest network off to see if it truly helps or if the above was just an aberration.
The switches are unmanaged TP-Link and D-Link.
they are too dumb to be the culprit
/in any case, I have run tests with temporary CAT6 running between them (which I so wish but unfortunately cannot keep)
