superczar
Jun 23, 2020Apprentice
Orbi system - Faulty LAN / switching design - Will NG ever fix it?
Issue - Orbi system with 2 satellites (R1, S1, S2) will randomly drop LAN communication between segments. e.g. devices connected to S1 (both wired/wireless) won't be able to ping devices on S2 (or ...
Mstrbig
Aug 21, 2020Master
I can say wired backhaul is a whole new and better advantage for mesh systems. some think it defeats the purpose of mesh and why not go separate routers or extenders. I've done them all, and the mesh system wins out every time. Good luck with the move.
Thw0rted
Aug 21, 2020Aspirant
I mean, it's still a "mesh" system even with wired backhaul, right? The key thing is communication between the nodes that facilitates smoother handoff when the client is moving around. This is the main reason I'm looking at mesh as an upgrade. I currently have a router from the ISP with one SSID for both bands, then a powerline AP and a wired AP (Nighthawk in AP mode) both of which use the same SSIDs, one each for 2.4GHz and 5GHz bands. Since all 3 devices are from different manufacturers, they don't do any sort of coordination as clients move around and they tend to "stick" to a crappy signal until you go in and manually pick a better network. I just want my network set up so that the mesh "knows" that it has a better receiver available and quietly boots the client over on its own, like a cellular network.
- GMoGoody8Aug 21, 2020Luminary
Thw0rted that's the dream right. I find the Orbi is pretty good with roaming clients. I have Fast Roaming Enabled. Just be advised the clients also need to play their part. They have to support all three of 802.11k, 802.11r, and 802.11v. These specifications are over 7 years old so hopefully all clients efficiently support them by now.
Apple put together a good explanation here: https://support.apple.com/en-us/HT202628 - Thw0rtedAug 21, 2020Aspirant
I did a bit of reading about this, and I think 11r only applies if you use Enterprise network security ("RADIUS", maybe?). The other two are supposed to be "hints" to the client, right? Anyway, the clients I'd be most concerned about are modern iOS, Android, Mac, and Windows devices. At the very least, I'm pretty sure they can't do worse than they are right now...
You are correct 802.11r predominantly benefits enterprise solutions, WPA2-Enterprise with Radius, but the specification also included enhancements to WPA2-Personal with efficiencies in establishing a new encryption key.
For both WPA2 Enterprise and WPA2 Personal re-associations. In both cases, the eight messages passed between an AP and a client device for authentication, association, and the four-way handshake are reduced to four messages.
Another thing to note is for all three of these specifications if you have mixed clients where some support them and other don't it is recommended to disable fast roaming since the older clients don't understand. - MstrbigAug 21, 2020Master
Thw0rted wrote:I mean, it's still a "mesh" system even with wired backhaul, right? The key thing is communication between the nodes that facilitates smoother handoff when the client is moving around. This is the main reason I'm looking at mesh as an upgrade. I currently have a router from the ISP with one SSID for both bands, then a powerline AP and a wired AP (Nighthawk in AP mode) both of which use the same SSIDs, one each for 2.4GHz and 5GHz bands. Since all 3 devices are from different manufacturers, they don't do any sort of coordination as clients move around and they tend to "stick" to a crappy signal until you go in and manually pick a better network. I just want my network set up so that the mesh "knows" that it has a better receiver available and quietly boots the client over on its own, like a cellular network.
I had 3 powerful routers in my home all brodcasting the same WIFI name. They worked quite well, but nowhere near as good as a mesh system. The backhaul makes all the difference, whether wired or wireless. The handoffs are way smoother. And wired backhaul, if possible, eliminates virtually all interference between the router and satellites. My system is ISP modem > orbi RBR50 > 12 port netgear switch > 2 Orbi RBS50 satellites and various hard wired devices > 8 port switch on each satellite, connecting various wired devices in each location. The system is super fast with no issues. WIFI speeds, from my phone, in the same room as the nodes are 478 down, 54 up (ISP plan 500/50). Of course the speed drops the further away I get from a node. But that is normal.
