OrbisUser95
Oct 08, 2020Aspirant
Orbi System Comparison
Has Negear produced a 1 page side by side comparison of Orbi model features so one can see everything on 1 page?
Oct 08, 2020Guru - Experienced User
- OrbisUser95Oct 09, 2020Aspirant
Thank you. I don't see the AX models in this chart. Did they only make one for the AC models?
- FURRYe38Oct 09, 2020Guru - Experienced User
Ya thats only for the AC models.
Not sure if or when NG will update to add AX models or not.
You can look at the spec sheets for the AX models to compare them there since theres only two model series.
Be sure to visit the Orbi AX Forum for help and informaton there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
