FredParis
Nov 25, 2019Aspirant
ORBI System components compatibility
Hello, I have since on eyear an ORBI system with a RBR20 and its satellite RBS20 and everything works well. Now, I want to extend the network to the roof terrace. I did tests with the RBS20 and it ...
FredParis
811/5000
Hello Plemans,
Thanks for your help. Yes the terrace of the building is built on concrete which makes the transmission of the signal difficult.
So I understand that the RBS50 will bring nothing more than the RBS20. I imagine two other solutions:
. Option 1 based on an RBS50Y located outside the shelter so closer to the source but with the risk of signal loss as when I did the test with the RBS20. It's not really satisfying!
. Option 2 based on NETGEAR PLP2000-100FRS (or equivalent), but I would have to keep the same original ORBI network for a good operation of my installation (I am also equipped with equipment connected to google home which must work on a single wifi network). I do not know if it's possible?
What's your opinion ?
Nov 26, 2019Guru - Experienced User
Concrete makes things challenging.
Potentially you could just run a powerline out to the patio and use then use an orbi connected to it. a lot depends on what circuit the powerline is on as occasionally powerline can have issues/slow downs with certain powerline devices.
I think that'd probably be your best bet for getting good coverage out there would be powerline for the orbi backhaul.
- CrimpOnNov 26, 2019Guru - Experienced User
Is this your building? (In the sense that you are able to install wiring?) I use PowerLine, with a total of four adapters. As plemans said, PowerLine is as much of a challenge as WiFi. Short distances on the same electrical circuit can get tremendous bandwidth. When PowerLiine connects to multiple circuits through the electrical panel, performance drops. I get 1,200mb from one bedroom to another on the same circuit, but only 120mb from the same bedroom out to the garage on a different circuit.
One "general rule" is to never penetrate a roof, but there seems to be a shelter up there with electrical power in it. Is there some way to run an ethernet cable to the shelter?
p.s. A pair of AV2 PowerLine adapters is about $100. I would not mess with the lower speed units.
Another thought. Did someone happen to run television coax to the terrace? (Or, maybe the cable TV feed comes to the building at the terrace level before going down into the house? A pair of MoCHA adapters is another possibility.
- FredParisNov 26, 2019Aspirant
This is not my building but I have an apartment and ath the upper level the roof top.
The ethernet cable is not possible but the roof top has electrical power on my circuit so the powerline should work. Of course, I need to check and especially that I need to test the performance!
the powerline is probably the best solution indeed, provided it keep the names and characteristics of those of the initial network ORBI for my google home system components.
