lohki82
Jan 21, 2018Guide
Orbi system is a dumpster fire
... I am so tired of this router and multiple daily disconnect and restarts. Multiple times a day I lose internet connectivity and have to wait for Orbi to reboot. I'm using the RBK40 system with 1...
DarrenM
Jan 23, 2018Sr. NETGEAR Moderator
Are you on the latest firmware 2.1.2.18? Have you updated all of your google/android devices connected to the network?
DarrenM
Randy771
Jan 24, 2018Aspirant
I dont know about the op but I certainly have. I have a BR50 and 4 BS50's and I ran the beta as well as .18 and iIe had nothing but isues. Can I get a recommendation as to the last stable firmware release?
- aazJan 24, 2018Virtuoso
I'm on 2.1.2.18 and it's been fairley stable for me as for many others. May I suggest you re-run the code update on all your satellites first then the router. clear your settings and reset up clean. Also for good measure turn off UPNP. Shut down your RBS's and try seeing if the router is stable, then slowly bring the RBS's on one by one. It must be something in your environment that is triggering the instability. Not to say that Netgear is not responsible for making it stable with any environmental conditions - but I think by modifying your environment you can get to a stable system like many of us are enjoying.
- timchJan 24, 2018Luminary
Really stable for me too, been up a week now on the latest firmware and not a glitch.
