cornishrex
Jul 21, 2019Aspirant
orbi system melt down RBR50
Please can some-one help me. I’ve had an orbi system for quite some time (over a year), all working fine. I was with BT and I had a modem at my incoming phone socket, linked to my orbi operating as a...
Jul 21, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
