Doug-48051
Mar 04, 2019Luminary
Orbi System RBR50 - Bandwidth Connection Issue with Amazon Echo
Hello All
I have been using the AC3000 Orbi System with the Amazon echo devices for over 15 months. I am using tp-link HS100 plugs switches to control my house lamps.
Today the Amazon echo do...
ekhalil
Mar 04, 2019Master
Doug-48051 wrote:
.......... Amazon is recommending to assign the Echo on the 2.4G network. The Orbi System uses the same SSID for both networks and does not allow for bandwidth steering.
Amazon Echo does not communicate with the TP-Link plugs through wifi as far as I know (I use Google Home which I believe uses the same integration concept as Echo). The communication happens through a cloud interface.
- Do you see both the Echo and TP-Link devices on the Orbi Attached Devices?
- If the answer to the above question is yes, then it must be just a "hiccup" in the cloud interface. Have you tried to remove one of the TP-Link devices from Echo and add it again and see if that will help?
Doug-48051
I see both devices in the Orbi Device list. I agree the logical answer is a hiccup. I updated my FW to the latest 2.1.2.232 version. I removed the Tp-link from the Amazon device list, but it will not add back in because it doesn't see them.
I am going to rest one the plugs and start from scratch. Wish me luck will keep all posted.
Now, where do I update my message board signature? LOL
