Bielski
Jan 02, 2019Tutor
Orbi Throttling Wired Ethernet connection
I noticed this morning that our RBR40 seems to be throttling our 200 Mbps Interenet speeds down to about 90 Mbps on the wired connections around my home. Wifi is at 200Mbps+. I did separate multiple...
- Feb 02, 2019
ekhalil FURRYe38 , After borrowing a thunderbolt to giagbit adapter, a usb-c to gigabit adapter and a very long cat 6 cable, I think I was able to determine that there may be a problem with the CAT 6 cable running from the RBR40 to the jack in my office. I connected the long CAT6 directly from my RBR40 to my Imac and got full speeds and 1000baset hardware. I connected my Macbook to the RBR40 and got full speed. I then connected my Macbook to the jack in my office and got 90mbps and 100baset hardware. I'm going to change the connector on the old CAT 6 and see if that restores full speeds. In the mean time wi-fi gives me full speed.
Bielski
Jan 07, 2019Tutor
I tried manually setting the Hardware and I got a cable unplugged and lost my ethernet. I will try changing ports and see what happens.
Jan 07, 2019Guru - Experienced User
Let us know how it goes.
- BielskiJan 08, 2019Tutor
FURRYe38, ekhalil, here's what I learned today. I did a speed test using my PS4 connected to a gigabit switch connected to a different port on my RBR40 on one end and another gigabit switch on the other that also feeds the 100Mbps Apple TV, and a DirecTV Genie Mini in another room. The PS4, which is 1000baset was averaging about 180 Mbps. I pulled the iMac newtork cable off of the RBR40 and plugged it into another port on the gigabit switch. My iMac is now getting 230 Mbps again. This makes me believe that there is definitely something wrong with the RBR40. I reached out to Blanca_O, supplied her with all my information and I'm waiting to hear back from her tech support team.
- FURRYe38Jan 08, 2019Guru - Experienced User
Ok, Ya seems like something is going on with the Base router. Let us know how it goes.
- ekhalilJan 09, 2019Master
1. Do you get the same results if you plug in the iMac on another port on the RBR40? Can this be an issue in just one of the ports?
2. If you have the issue in all ports then I doubt that this is a HW fault and it must be an issue in the Autonegotiation in the Orbi's Ethernet ports.
Please play around with the iMac Ethernet settings under System Preferences > Network > Select Ethernet on the left side > Select Advanced > Select Hardware Tab. Try manually and then select different alternatives from the Duplex and the MTU options.
