Bielski
Jan 01, 2019Tutor
Orbi Throttling Wired Ethernet connection
I noticed this morning that our RBR40 seems to be throttling our 200 Mbps Interenet speeds down to about 90 Mbps on the wired connections around my home. Wifi is at 200Mbps+. I did separate multiple...
- Feb 02, 2019
ekhalil FURRYe38 , After borrowing a thunderbolt to giagbit adapter, a usb-c to gigabit adapter and a very long cat 6 cable, I think I was able to determine that there may be a problem with the CAT 6 cable running from the RBR40 to the jack in my office. I connected the long CAT6 directly from my RBR40 to my Imac and got full speeds and 1000baset hardware. I connected my Macbook to the RBR40 and got full speed. I then connected my Macbook to the jack in my office and got 90mbps and 100baset hardware. I'm going to change the connector on the old CAT 6 and see if that restores full speeds. In the mean time wi-fi gives me full speed.
ekhalil
Jan 20, 2019Master
Interesting! Please keep us updated.
Bielski
Feb 02, 2019Tutor
- ekhalilFeb 02, 2019Master
Great, sounds like you're on the correct track. Good luck!
- FURRYe38Feb 02, 2019Guru - Experienced User
Glad you were able to narrow it down and it was a cable issue and not a router issue.
Be sure to mark your forum post solved so other will know for future reference.
Enjoy. :smileywink:
