Ulairi
Mar 17, 2018Luminary
Orbi Throttling Wired Ethernet connections?
Has anyone experienced the Orbi system apparently throttling otherwise good connections? I have a plan with 200 Mbps down and 20Mbps up. My connection speeds were consistent on this plan until I...
- Apr 15, 2018
FURRYe38 wrote:Glad it's working well now. This is what I have been saying all along. Glad someone believes now.
Thanks for your advice and help.
The advice for performing a full factory reset has only, to my knowledge, been previously discussed on this forum in the context of stability, dropped connections and upgrading firmware. I hadn't seen any discussion about doing a factory restet in the context of the speed throttling issue.
There are a small number of threads on the forum where speed throttling is reported and queried. It seems to be an uncommon fault. Most advice focuses on the test environment (test PC, cables and whether in AP or router mode). I don't recall anyone suggesting a 'factory reset' for this internal bottleneck. Indeed - up until now - no one appeared to acknowledge that the Orbi could have an internal software bottleneck.
I think that my experience clearly shows that an internal bottleneck has occured in the software within the Orbi router. Back-to-back testing against two other routers - keeping the test environment the same - clearly showed that the Orbi was the culprit. This was supported by the Ookla results on the Orbi's QoS page showing that the Orbi was, indeed, getting the full speed in to it (before Ookla took this feature down on the Orbi last week). The problem persisteted, despite re-flashing the router with three different firmware loads. Once I did the factory reset, I immediately got the full download speed from my ISP.
Also, since the reset, I've also noted that I'm now getting very good speeds over WiFi connections as well. The Orbi was throttling all connections - not just Ethernet.
If anyone has speed bottlenecks then a 'factory reset' is the way to go. I think that this is new information - because previous advice focused on cables, the test PC and the mode of the router.
Apr 14, 2018Guru - Experienced User
Enjoy.
Ulairi wrote:I've been experiencing a speed bottleneck issue for a while ever since I got the Orbi a couple of months ago. It initially set up with with firmware V2.1.1.18 and I reverted to V2.0.0.34 and V2.0.1.2. Updating firmware to V2.1.3.4. today, similarly, made no improvement.
However, I'm pleased to report that a subsequent factory reset (as painful as it was to re-establish everything) got my full download speeds back. 200Mbps every time (previously averaging 75 Mbps and as low as 30 and as high as 110 Mbps)
For anyone struggling with the Orbi performance, don't hesitate - bite the bullet and try a 'factory reset' .
Ulairi
Apr 15, 2018Luminary
- FURRYe38Apr 15, 2018Guru - Experienced User
I believe that there is NAT accelleration or NAT Cut-Through that maybe employed on these routers. This is needed for high speed ISP support, 900Mb+-. I believe that some of the features like QoS, Access Control and Traffic Meter may disable this NAT accelleration feature from what others have said and posted about. So doing a factory reset and having users not enable or touch upon these features has reported higher speed tests for those having 1Gb ISP services. So be aware of this issue with a few of these router features and NAT accelleration on high speed ISP services. Other factors are wireless which some if not most current wireless clients are limited in higher speeds and will usually max out at around 400mb to maybe 600Mb on the high end. Users need to check with there client hw mfrs to see what thruput speeds are supported on there devices.
Lan cable speed testing is always preferred.
