Ulairi
Mar 17, 2018Luminary
Orbi Throttling Wired Ethernet connections?
Has anyone experienced the Orbi system apparently throttling otherwise good connections? I have a plan with 200 Mbps down and 20Mbps up. My connection speeds were consistent on this plan until I...
- Apr 15, 2018
FURRYe38 wrote:Glad it's working well now. This is what I have been saying all along. Glad someone believes now.
Thanks for your advice and help.
The advice for performing a full factory reset has only, to my knowledge, been previously discussed on this forum in the context of stability, dropped connections and upgrading firmware. I hadn't seen any discussion about doing a factory restet in the context of the speed throttling issue.
There are a small number of threads on the forum where speed throttling is reported and queried. It seems to be an uncommon fault. Most advice focuses on the test environment (test PC, cables and whether in AP or router mode). I don't recall anyone suggesting a 'factory reset' for this internal bottleneck. Indeed - up until now - no one appeared to acknowledge that the Orbi could have an internal software bottleneck.
I think that my experience clearly shows that an internal bottleneck has occured in the software within the Orbi router. Back-to-back testing against two other routers - keeping the test environment the same - clearly showed that the Orbi was the culprit. This was supported by the Ookla results on the Orbi's QoS page showing that the Orbi was, indeed, getting the full speed in to it (before Ookla took this feature down on the Orbi last week). The problem persisteted, despite re-flashing the router with three different firmware loads. Once I did the factory reset, I immediately got the full download speed from my ISP.
Also, since the reset, I've also noted that I'm now getting very good speeds over WiFi connections as well. The Orbi was throttling all connections - not just Ethernet.
If anyone has speed bottlenecks then a 'factory reset' is the way to go. I think that this is new information - because previous advice focused on cables, the test PC and the mode of the router.
TreborNewob5
Apr 22, 2018Guide
Hi, I had almost the same.
Virgin Media 200 meg on Lan network and about 70 to 80 meg on WiFi with no lag or signal breakup.
Then fitted Orbi Lan no change but WiFi 200plus :)
Then had my Viggin Boxes upgraded to the new V6 Tivo and the engineer conected both boxes via cat 7 cables and all was fine but now had to go back to WiFi as the Lan connection to Orbi and the Satelite started breaking only for a few seconds stopping any recordings of TV programs. But on WiFi all is well.
And before you say contact Netgear Support don't go there , they are as much use as a chocolate fire guard.
And no doubt like the failing speed test App issue all will be fixed but they will never post the problems to their customers.
That would mean giving Support!
Ulairi
Apr 23, 2018Luminary
TreborNewob5 wrote:Then had my Viggin Boxes upgraded to the new V6 Tivo and the engineer conected both boxes via cat 7 cables and all was fine but now had to go back to WiFi as the Lan connection to Orbi and the Satelite started breaking only for a few seconds stopping any recordings of TV programs. But on WiFi all is well.
Are you on the latest (Beta) frimware and, if so, have you done a factory reset with the change to latest (beta) firmaware? If not, and acknowledging that its a right royal PITA, I'd recommend a factory reset.
