staralfur428
Oct 08, 2019Aspirant
Orbi to Airport express wired connection breaks orbi
I have a few airport expresses I am using for their Airplay2 function into various receivers/speakers/etc. I have them all set up to “join a wireless network”. Not to “extend” not “create”. I also ...
staralfur428
Oct 10, 2019Aspirant
I think I must have written it incorrectly.
I’m using the RBS connected to the RBR wirelessly. It’s about 30 feet from the RBR without any walls in the way. Right now I have my AE connected to the RBS via Wifi. Connection is good, but in effort to reduce WiFi noise I am trying to connect the AE as a client via Ethernet. Connecting an Ethernet cord to the AE input port.
Oct 10, 2019Guru - Experienced User
When you connect the AE using it's LAN port to the system, this would turn the AE in to a wireless AP, thus adding more noise to the system. Having the AE connect wirelessly as a client to the RBS would not add noise to the system.
- staralfur428Oct 10, 2019AspirantI never thought of it that way. however, I have the AE set to “join and existing network” and thus shouldnt it not function as an access point anymore, but rather function as a client (like my computers and Apple TVs that are hardwired into the system do)?
- FURRYe38Oct 10, 2019Guru - Experienced User
Correct.
- staralfur428Oct 10, 2019AspirantYes: I have it set that way, to “join existing network”
And yet instantly when I plug the RBS into The AE input it causes a magenta ring and it actually ruins the rest of the satellites too. So I’m
Failing to understand what you are saying. I have it set up in client (aka join existing network mode)
Not trying to be confrontational, I really appreciate the help
