stacyclayton
Mar 05, 2019Follower
Orbi to DC112a
Is it possible to connect the Orbi to a Netgear DC112A Aircard Cradle?
- Mar 05, 2019
thombe wrote:
i'd disable wifi and setup orbi as AP.......
Correct thombe , this is one option (disable wifi in theDC112a and setup Orbi in AP Mode).
Another option is to keep Orbi in Router Mode and set the DC112a in Bridge Mode as you can see in page 71 of the DC112a manual.
Mar 05, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend AP #(3), mode as suggested...
