mwhals
Feb 27, 2018Tutor
Orbi to improve coverage?
My house is 2650 square feet and is one level. My R7000 is about 1/3 back from the front of the house and 2/5 from the right of the house. I have a poor signal in the room at the right back of the hou...
- Mar 03, 2018With the Orbi issues, I decided to try relocating my AC1900 Nighthawk to the other side of the office. This was great as it covers the whole house now. No need to get the Orbi in my opinion.
Thanks for all the help that was provided.
nicholb
Feb 27, 2018Luminary
Another thing to consider is you don't want to put the satellite(s) in areas of poor reception. They need to be within the area of good connection so they can boost that over to the the poor areas. So if you put the Orbi router in the room where the R7000 is, you would want to have the satellite somewhere between the router and where you are not getting good reception. Ideally you want the satellite at the edge of the router's good reception area. Think overlapping circles.
