mwhals
Feb 27, 2018Tutor
Orbi to improve coverage?
My house is 2650 square feet and is one level. My R7000 is about 1/3 back from the front of the house and 2/5 from the right of the house. I have a poor signal in the room at the right back of the hou...
- Mar 03, 2018With the Orbi issues, I decided to try relocating my AC1900 Nighthawk to the other side of the office. This was great as it covers the whole house now. No need to get the Orbi in my opinion.
Thanks for all the help that was provided.
mwhals
Feb 27, 2018Tutor
I was not successful making the R7000 an access point, because I do not have a second router. I did find that I do get 100 Mbps in my back two rooms with just the R7000. I want to get closer to 200 Mbps all through the house and may go up to 400 Mbps service.
Feb 27, 2018Guru - Experienced User
The R7000 needs a primary host router to connect to when in AP mode.
The R7000 may not have the power or range to reach remote locations. Either adding a extender or installing a Orbi system would be options to review.
- mwhalsFeb 27, 2018TutorI am going to look at Orbi systems tomorrow. I will keep the R7000 as a router and firewall. The Orbi would be set up as an access point.
I am not interested in 2 band extenders due to the speed penalty and separate SSID.- FURRYe38Feb 27, 2018Guru - Experienced User
well if you think about it, Orbi is kind of using two ssids, just depends on location and which closer signal your device will connected to. The router puts out a signal as well as the Satellite.
The Orbi will be good for your needs. I would disable the wifi on the R7000 router if your going to keep it as your main host router. Then connect the Orbi up in AP mode.
I am not interested in 2 band extenders due to the speed penalty and separate SSID.- mwhalsFeb 28, 2018TutorI saw on Amazon a review of the rbk53 with a one story ranch house the same size as mine and they said it worked beautifully. We have 7.3 acres, so if the signal spills into our land, that is good since my cell phone would connect in the yard.
Amazon has the RBK53 for $20 more than the price Best Buy has the RBK43, so it is a no brainer for me. Either would work though.
I had planned to disable the R7000 wireless, so it would be one SSID instead of two. The Orbi would be used as an access point. Keeping the R7000 is important to me as it’s firewall has stopped a couple of attacks and the Orbi does not have a firewall. I could use a small Netgear non Wi-Fi router for the same reason. I may do that anyway to save space on the bookcase.
