mwhals
Feb 27, 2018Tutor
Orbi to improve coverage?
My house is 2650 square feet and is one level. My R7000 is about 1/3 back from the front of the house and 2/5 from the right of the house. I have a poor signal in the room at the right back of the hou...
- Mar 04, 2018With the Orbi issues, I decided to try relocating my AC1900 Nighthawk to the other side of the office. This was great as it covers the whole house now. No need to get the Orbi in my opinion.
Thanks for all the help that was provided.
mwhals
Feb 28, 2018Tutor
I am going to look at Orbi systems tomorrow. I will keep the R7000 as a router and firewall. The Orbi would be set up as an access point.
I am not interested in 2 band extenders due to the speed penalty and separate SSID.
Feb 28, 2018Guru - Experienced User
well if you think about it, Orbi is kind of using two ssids, just depends on location and which closer signal your device will connected to. The router puts out a signal as well as the Satellite.
The Orbi will be good for your needs. I would disable the wifi on the R7000 router if your going to keep it as your main host router. Then connect the Orbi up in AP mode.
