BRS918
Jun 15, 2020Aspirant
ORBI topology?
I have a 4500 SF two story home - ground floor is about 3,000 SF with the balance on the 2nd story. I have a 3000 SF shop (metal building) that is approximately 100' from the house (line-of-site). ...
CrimpOn
Jun 15, 2020Guru - Experienced User
A metal shop building is sort of a "worst case scenario". WiFi signals do not penetrate metal walls very well. So, "no". An Orbi unit inside the house is highly unlikely to be usable inside the metal shop building.
The best performing solution is to run a Cat6 ethernet cable from the house to the shop inside a PVC conduit. Cat6 supports gigabit connections up to 328 ft. (including patch cables), so the shop building is well within that limit even if the cable cannot "go in a straight line" from house to shop. While the cable itself is not expensive, the cost to create the conduit pathway can be considerable.
Yes, Netgear does sell an "outdoor rated" unit, the RBS50Y. Placing it "half way" runs into the same issues with the metal building.
Depending on how the house and shop are connected at the transformer/electrical panel, you might be able to use Powerline adapters. It would be an easy experiment to set up.
The most convenient method of bridging such a gap is to install a pair of WiFi "bridge" units to create a point-to-point link. Every major WiFi vendor offers one or more such products. Devices on each end of the link think they are connected to a regular ethernet cable. Although most bridge units are designed for outdoor mounting, they also can be installed inside, for example stuck to a window.
BRS918
Another thing I neglected to mention is that the shop and the house on separate electric meters and have their own service panels. To my knowledge the first common component in the sytem is the high voltage step down transformer. I'm not certain but pretty sure using the electrcial wiring to extend the network, wouldn't work very well having to go through the panels, meters and transformer, if at all!?!?
