Maroman
Mar 26, 2019Guide
Orbi Traffic meter and Daylight savings
The traffic meter feature in the Orbi only works if you disable daylight savings time. That works but for some reason daylight savings becomes enabled again then the traffic meter stops working again....
CrimpOn
Mar 26, 2019Guru - Experienced User
Oh, my! I have always had Traffic Meter turned on with "No limit" and check it every couple of months just for entertainment. Sure enough, when I checked today it was turned off during the firmware update. Enabled Traffic Meter and after waiting a bit, "Today" remains at zero. (I can understand the recent firmware update wiping out past records.)
Did not turn off Daylight Saving Time.
